engine oil life reset?
18,330 MILES • 6 CYL • 2WD • MANUAL
RLSTUFF104
I changed the oil myself and I would like to find out how to reset the change engine oil warning?
Oct 1, 2008 at 8:35 AM
PSYCONLOVE03
Turn the key on , but dont start the truck. press the gas pedal to the floor and release 3 times. Then turn the key off. Start your truck. THe display should read oil life reset.
Oct 21, 2008 at 10:37 PM
MCGEADY11
This is a two part question. 1. On my display the language keeps changing at random times and right now it seems to be stuck on french. What can I do to change it back to english and/or what can I look for as far as causes for this? 2. I recently had the " Change engine oil" message come up on my display and after changing the oil it is still coming up when I start my truck. Is there something that I need to get reset or will this go away after the oil runs through the system for a while?
Sep 3, 2020 at 4:42 AM (Merged)
MMPRINCE4000
  • 8,548 POSTS
Check your owners manual on both problems.
The oil light simply needs to be reset, but the display should not randomly change.
Reset both according to owners manual, but if display changes again, then a problem with radio electronics, or programming is not complete.
FORCES_90
My truck was running literally 5 minutes ago I forgot something at the house I put it in reverse backed into the parking spot turn the truck off and went into the house at that point I came back outside and attempted to start the truck it will not start continues to say change oil and oil life reset please help me I need to work tomorrow
HMAC300
  • 48,601 POSTS
try resetting anti theft. then check battery for condition including load test.
2CP-ARCHIVES
  • 4,540 POSTS
my vehicle is equipped with an after market radio. What is the correct way to reset your oil life?? Cannot seem to find the reset button for this..or the book states " select button ", is it located on the original radio ??
key on engine off. push accelerator pedal to the floor 3 times in 5 seconds.
REDBOAT63
I change my own oil. I follow the directions in the manual to reset the warning light. But it still says my oil is at 90% . Is there a way to get it to say 100% ?
AIRSOFTSOLDRECN9
  • 348 POSTS
You will have a bit of old oil left in the system if you just drain it and change the oil filter. My guess it is a 5qrt system so 10% would acount for 1/2 qrt. May not seem like a lot but your crankshaft, valvtrain and pan can hold residual oil that may account for your 10%, also sludge and other deposits too. Now the way you actually change oil, at a dealership or higher end service stations (lol not jiffy lube) they use a cycling system to send in fresh oil through the car and pump out the old. Once the color changes or my guess the computer on the device says the oil is completely clean then all the residue is gone and everything is good. This is wonderful since it removes sludge and all sorts of gunk out of the engine. You may never get 100% clean oil on the engine but honestly if you like doing it then by all means please do; you are one of few americans who take the time to do so and its something to be proud of.
THE FACTORY MAN
  • 50 POSTS
[quote:7686a14426="airsoftsoldrecn9"]You will have a bit of old oil left in the system if you just drain it and change the oil filter. My guess it is a 5qrt system so 10% would acount for 1/2 qrt. May not seem like a lot but your crankshaft, valvtrain and pan can hold residual oil that may account for your 10%, also sludge and other deposits too. Now the way you actually change oil, at a dealership or higher end service stations (lol not jiffy lube) they use a cycling system to send in fresh oil through the car and pump out the old. Once the color changes or my guess the computer on the device says the oil is completely clean then all the residue is gone and everything is good. This is wonderful since it removes sludge and all sorts of gunk out of the engine. You may never get 100% clean oil on the engine but honestly if you like doing it then by all means please do; you are one of few americans who take the time to do so and its something to be proud of.[/quote:7686a14426]
**The Oil Life Monitor DOES NOT sample the oil.** It calculates the oil life based on a very complex computer algorythym and it monitors miles driven, temperatures, drive cycles and several other sources of input. I am not sure why your system only shows 90% when you reset it, mine showa 100% for a very short time on my 2005 Silverado.
SPEEDEX
how do i reset my change oil light on my 2002 chevy silveraldo?
FREELAND
I believe with the ignition in the on postion (not running) press on the gas pedal 4 times. this should reset the computer.
1BIGDOGG
2001 Chevy Silverado
I did the oil change but still get message to change the oil. How do i reset or erase this message?
INTERNETMECHANIC
  • 700 POSTS
You might try this. The only other reset I saw, was 2005--2009. I realize your were talking about a message, this info is all I found.
https://images.2carpros.com/forum/automotive_pictures/512072_silverado_oil_life_reset_1.jpg
MICHJMILLER
How do you reset the message center after an oil change so that it doesn't keep telling you "change engine oil soon"?
  • 55,542 POSTS
Turn the key on without starting the engine. Press gas pedal to the floor five times within 10 seconds. Then shut the key off and you are all set. Start the vehicle, you may need to do this a few times if it doesn't work the first time.
Cheers, Ken
