2006 Chevy Silverado
ROBERT WILBURN
  • 2006 CHEVROLET SILVERADO
  • V8
  • 4WD
  • 59,000 MILES
My 2006 Chevy Silverado Truck is using oil, at 59000 miles. I am using Castrol Full Synthic oil 5w-30, never used anything else, what should I do
Wednesday, July 28th, 2010 AT 8:58 PM
  • 109,885 POSTS
How much are you using? Are there any leaks? Is it burning it?
Sunday, August 1st, 2010 AT 11:14 PM
ROBERT WILBURN
It's using between 1 to 2 quarts, can't find any leaks, and it's not smoking, or missing. Oil pressure gague moves from around 30 when idleing 40 whendriving, power seems to be ok. ( Using 1 to 2 quarts between oil change). Thanks!
Thursday, August 5th, 2010 AT 7:49 PM
  • 109,885 POSTS
If you are using 1 or 2 qts between oil changes (I will assume every 3K) believe it or not, that isn't excessive. The engine is burning it, but such a small amount, you can't see it. Some manufacturers say it is normal to use a qt every 1K.
Friday, August 6th, 2010 AT 12:55 AM
