temp gauge is a littlte higher,and i have water in passenger floor board
Jan 5, 2010 at 4:02 AM
BLUELIGHTNIN6
✓Experienced Mechanic
hello and thanks for the donation!
is the coolant in the passenger side floor? do you notice a slight filmy substance on the windshield if heater is on defrost? if so suspect faulty heater core. if not then check heater hoses running to heater core, if one is loose or damaged it will leak coolant into floorboards.
Jan 5, 2010 at 4:07 AM
DEXTMAD
MEMBER
thats what i was thinking ,but no coolant yet.do i have to take dash apart to check hoses?
Jan 5, 2010 at 4:16 AM
BLUELIGHTNIN6
To check the hoses remove the access panel nut near the pollen filter.
Remove the access panel.
Inspect the hoses and also check the water flow control valve.
Jan 5, 2010 at 4:58 AM
USNINIASEN
MEMBER
I had this problem with my previous 05 Silverado, and finally found that the firewall seal near the brake master cylinder was not tight.
Jul 22, 2025 at 11:56 AM
