2005 Chevy Silverado speedometer stuck
TASCHEVY
Engine Mechanical problem
2005 Chevy Silverado Two Wheel Drive Automatic
My speedometer has went past the peg and is now stuck how do you take the dash off
Jan 22, 2010 at 1:50 AM
SCOTTY DEE
  • 592 POSTS
The instrument cluster is bad. Remove the bezel around the cluster and there are four screws around the cluster assembly. Remove the ribbon from the back of cluster. Depending on the model an upload may be needed to program the new cluster.
Jan 27, 2010 at 1:01 AM
