2005 Chevy Silverado Oxygen Sensor Replacement
147,000 MILES • V8 • 4WD • AUTOMATIC
JRSCHWAGER
Our 2005 Silverado 2500HD has been in for replacement of the OEM sensors. The codes state the heaters are bad. The sensors have been replaced twice and the check engine light continues to come on. The dealer can't seem to get this corrected. Is there a certain way to replace these sensors or something they are missing when doing the replacement (like resetting a code or something)? Thank you!
Sep 3, 2010 at 6:39 AM
DOCFIXIT
  • 18,828 POSTS
Hi
What are codes in P0xxx format? Most likely a wiring fault or PCM failure.
Let me know
Thanks for donate
Sep 3, 2010 at 6:54 AM
