2005 Chevy Silverado OBDII P0449
2005 CHEVROLET SILVERADO
103,000 MILES • V8 • 4WD • AUTOMATIC
MAKO22
Evaporative Emission Vent Vlave Solinoid Circuit.
What does this mean and how do I fix the problem?
Jun 22, 2009 at 12:49 PM
BLUELIGHTNIN6
  • 16,542 POSTS
DTC P0449 : Evaporative Emission (EVAP) vent Solenoid Control Circuit
This code is very common on this vehicle. The solution the majority of the time is to fix the wiring to the evap vent. The connector to the valve loses ground from the computer. At the pigtail, the wire turns green (corrodes) and loses the connection it needs. Replace the pigtail with #pt250. Be sure to use the updated valve and relocate the filter as well. If the wiring tests and looks OK, however, then suspect a faulty EVAP vent solenoid.
Jun 22, 2009 at 1:20 PM
MIKEVI
[quote:79cca882c7="bluelightnin6"]DTC P0449 : Evaporative Emission (EVAP) vent Solenoid Control Circuit
This code is very common on this vehicle. The solution the majority of the time is to fix the wiring to the evap vent. The connector to the valve loses ground from the computer. At the pigtail, the wire turns green (corrodes) and loses the connection it needs. Replace the pigtail with #pt250. Be sure to use the updated valve and relocate the filter as well. If the wiring tests and looks OK, however, then suspect a faulty EVAP vent solenoid.[/quote:79cca882c7]
Nicely done , but kindly be clear what a #pt250 is, A terminal? connector?
Aug 4, 2009 at 1:09 PM
BLUELIGHTNIN6
  • 16,542 POSTS
its the updated pigtail connection
Aug 6, 2009 at 1:57 PM
