2005 Chevy Silverado low idle
COGGONBOB
Engine Performance problem
2005 Chevy Silverado V8 Four Wheel Drive Automatic
idles about 500rpm but drops to 300rpm or dies when put in gear (drive-reverse) can the idle speed be adjusted?
Mar 2, 2010 at 3:02 AM
LEGITIMATE007
  • 5,121 POSTS
well not really, your idle is adjusted by the computer, through the idle air control valve, however, you may want to clean out your throttle body and throttleplate, along with the bore and pintle of the IAC.
Mar 2, 2010 at 3:36 AM
