2005 Chevy Silverado Loud Shuddering Noise at End of Stop
40,000 MILES • 6 CYL • 2WD • AUTOMATIC
AGILBREATH
At the end of a stop, my pickup comes to a loud, grinding, shuddering stop. Shakes the whole cab.
Has recently started inhibiting the acceleration after stopping. Feels like brakes are grabbing, releasing, grabbing, releasing. Very load noise. Sounds like metal to metal.
Had brakes inspected and very trustworthy mechanic could not see ANY damage to brakes
He drove it numerous times and couldn't even get the "shuddering" stop to occur. Pickup went about a week after the inspection and then started up shuddering again.
Losing my mind, please help with suggestions.
Jan 8, 2010 at 10:41 AM
QUAGMIRE86
  • 98 POSTS
Sounds like one or more of your brake calipers are binding/sticking. The problem could be that a caliper pin is binding and not letting the caliper go back to a nuetral position. (I had a left rear caliper pin sieze up and on occasion, the whole truck would shudder going down the road). The caiper pin looked like it was welded into the cailper. I broke/sheared off two T-55 torx bits and twisted a 3rd around where it looked like a drill bit before it broke loose (after applying heat to the pin). There was no lubrication left on the pin causing the caliper to bind against the disk.
If the caliper pins are ok, then you may have some foreign material blocking the brake fluid to return through the master cylinder or ABS system.
Also, if you have the disk brakes in the rear, check the status of the brake shoes that are used for the emergency brake system. If the mechanic just checked the condition of the pads and didn't remove the disks, there is no means to inspect the brake shoes of the E-brake.
Jan 8, 2010 at 2:23 PM
