2005 Chevy Silverado HOT air...sometimes
43,000 MILES • V8 • 4WD • AUTOMATIC
ELWOPO
This truck has the 6.6 diesel engine.
Sometimes...about once every two days...the driver's side air (just that side) will start to blow hot....really hot. Hitting the a/c button does nothing. Moving the slider does nothing. Usually turning the truck off and starting again gets the air cold as usual. Sometimes it will start hot, but usually it will just change after the cold has been blowing for a while.
Ever seen this before?
Thanks in advance!
Apr 4, 2008 at 8:51 AM
MASTERTECHTIM
  • 4,750 POSTS
there is a technical service bulletin for a similar condition and the fix is to have the hvac reprogrammed at the dealer. hope this helps
Apr 4, 2008 at 10:11 AM
