2005 Chevy Silverado front end clunking
2005 CHEVROLET SILVERADO
ANTHONY BOHEN
Suspension problem
2005 Chevy Silverado Engine Size unknown Four Wheel Drive Automatic 98000 miles
I have a 2005 chevrolet sileverado duramax 4x4. I have an annoying clunking noise in front end. It is only noticable when hitting larger bumps(if you will). I have had it to the chevy dealer 3 times and they cannot find the problem. I picked up today (again) and they put a new steering shaft rod in it thinking that was the problem. Wrong! I exited the dealership and when I turned to leave hitting a bump the clunk was still there ($150.00 later). I am thinking shock or strut. The alignment is fine and so is tire wear. Any suggestions were to start looking?
Feb 19, 2008 at 5:31 PM
2CARPRO JACK
  • CAR REPAIR CONTRIBUTOR
  • 11,533 POSTS
Will it do it if you hit just one wheel on a bump? start by checking the sway bar bushings and shock bushings. Does it only do this if the wheel is turned?
Feb 19, 2008 at 5:47 PM
DENNYP
  • 1,824 POSTS
I have seen many of the upper shock bushings wear through and cause a clunk noise.
Feb 19, 2008 at 9:54 PM
