Interior lights?
63,000 MILES • V8 • 4WD • AUTOMATIC
CODYBULLARD
  • 5 POSTS
I just bought this truck and the interior lights on a couple of different things when I bought it didnt work. I drive down a lot of bad dirt roads for my job and now the lights that didnt work before (button lights on my steering wheel) do and the 4x4 lights dont. Also this morning one of my fog lights was coming on and off. How can I fix the wiring so this doesnt happen?
Mar 5, 2009 at 12:02 AM
RACEFAN966
  • 5,029 POSTS
Ok is sounds like you may have a body control module issure. The body control module controls interior and exterior lighting and more. If you have a digital multi meter and would like to do a couple of tests we can determine that. Get back to me.
Mar 5, 2009 at 2:39 AM
CODYBULLARD
  • 5 POSTS
I really appreciate your help but I dont have a digital multi meter, I went to auto zone to get them to use theirs and it was the $40 junk edition (I guess thats why they do it for free) and they said the one that I need is about $1500 and thats just not even gonna come close to affordable for me, so what can I do.
Mar 10, 2009 at 2:57 AM
RACEFAN966
  • 5,029 POSTS
All you need is a 20 dollar or so digital multi meter. Here is a pic of what you can get so we can do some voltage and ohm's testing ok. Kinda like this one will work just fine. They are trying to sell you a scanner instead.
https://images.2carpros.com/forum/automotive_pictures/249564_c13632e4c5dbb05c_1.jpg
Mar 10, 2009 at 3:07 AM
CODYBULLARD
  • 5 POSTS
Thats alot cheaper I think I can handle that. Can I get one of these at auto zone or some place like that?
Mar 10, 2009 at 3:10 AM
RACEFAN966
  • 5,029 POSTS
Yes you can get them at a parts store or home depot or a hardware store. Just make sure it is digital and that it has volts and ohm's and will work on a 12 volt system. Now most meters will not have a 12 volt setting it will be a 20 volt setting. This one has all the setting that we need and more for only about 21 dollars and tax. I hope you can blow it up some and see what I mean. I am not saying you don't understand what I mean I just know that sometimes a pic can clear it all up.
https://images.2carpros.com/forum/automotive_pictures/249564_14572_1.jpg
Mar 10, 2009 at 3:30 AM
CODYBULLARD
  • 5 POSTS
Ok I got a Fluke multi-meter that my electrician buddy gave me and he said that it would work.
Mar 12, 2009 at 11:58 PM
RACEFAN966
  • 5,029 POSTS
Ok first thing is you need to get access to the lower part of the steering column. On the left side of the column is the body control module. I will include a pic number 3 is the module and 4 is the harness to the module ok. So first I need you to see that the 3 orange wires to the module all have power and they should be hot at all times so the key doesn't need to be on for this. Just to let you know this module controls everything other then the engine electrical. I mean it runs the interior lights it runs the anti theft and door locks, sound system, wipers and washer and A/C and etc. Now get back to me with what you find and we will go from there.
Mar 13, 2009 at 4:07 AM
BOOTS FOX
when i turn the heater on it will not come on and the interior light will not come on as well
Sep 14, 2020 at 4:31 AM (Merged)
  • 110,248 POSTS
Have you checked fuses? If so, have you checked to see if the blower motor is getting power?
THETUCKA
I have a 2005 chevy silverado with interior lighting problems. The courtesy light for when the door opens doesn't work when I open the door nor when the key comes out of the ignition like it used to. It does work fine when I unlock the doors using the remote. I also have a couple of lights out on the steering wheel that control the radio. Not sure if is related, but I recently had the gauge cluster replaced at the dealership due to a recall and everything worked fine before then.
HMAC300
  • 48,601 POSTS
ther are 2 fuses for the courtesy light they are 2B and 2C on the lower left fuse box. Unless there are loose connections from the the new gage cluster being replaced it would be either a door module or body module out of whack it seems. unfortunately you need a tech 2 scanner to test these to see what's wrong. they are usually only at dealers.
HARVEYLOVE
I blew the fuse for the for the interior lights in my 2002 Chevy Silverado. I changed the blown fuse but the lights still wont come on.
BMRFIXIT
  • 19,053 POSTS
Recheck all fuses using a test light check the bulb any thing else isn't working if all checked OK need the help of a scanner to test the relays , BCM module and wiring
https://images.2carpros.com/forum/automotive_pictures/99387_chey_1.jpg
https://images.2carpros.com/forum/automotive_pictures/99387_chey1_1.jpg
https://images.2carpros.com/forum/automotive_pictures/99387_chey11_1.jpg
RHERLING
every time you open door i blow the the 15 amp fuse i have cheked all interior lights and cago plus under hood lights for bad wires or shorts all looks good
  • 110,248 POSTS
Have you checked light sockets?
RHERLING
yes all light socket that goes withthat fuse
  • 110,248 POSTS
If you remove all light bulbs, will it still blow the fuse? Also, check the owner's manual and see what other accessories are run from the same circuit.
BJACOBSON39
i have a 2002 chevrolet silverado 1500, my dome and interior lights are stuck on, i was wondering if there was a relay that would cause this problem?
Thanks
MIKE H R
  • 3,094 POSTS
check the courtesy light switch on the door, If one is broken and making contact and grounding out making the light stay on , also check the dash light dimmer switch to make sure it is off.
TYLERPOWELLS
The driver side door unlock button and window up and down buttons no longer light up. How do I fix this?
RHALL77
  • 3,361 POSTS
its in the switch assembly. try to unplug it and plug it back in. they may come back on then because it is a drivers door module. if that doesnt work you will most likey have to replace it
