2005 Chevy Silverado Fan only works on 1,2,3,4, not 5
60,000 MILES • V8 • 4WD • AUTOMATIC
ALARGEN
I need to know what i need to check and change before i take it to the dealer to save a little bit of money. The problem just started for no reason to my view but i just would like to get it fixed and im not sure if its the transistor or a fuse or the blower motor its self im not real sure but when i turn the knob up they all work except 5 .. Thanks
Nov 4, 2008 at 12:36 PM
DENNYP
  • 1,824 POSTS
You probably have a melted connection at the red wire on the blower resistor connector. You will need to replace the blower resistor and wiring connector. You can get the parts at the dealer.
Nov 4, 2008 at 12:42 PM
