2005 Chevy Silverado coolant mixed with gas
TROY WALTON
Engine Mechanical problem
2005 Chevy Silverado 6 cyl Two Wheel Drive Automatic
truck an out of gas. I got gas from friend in gas can I later found out it also had anti freeze. now truck won't run properly what do I need to do to fix problem?
Aug 13, 2008 at 8:23 AM
  • 75,988 POSTS
If you're saying its in the fuel tank it don't go there-some one put it there maybe a good friend? Check the fuel pressure could be the fuel filter/fuel pump and report back
Aug 13, 2008 at 8:47 AM
RHALL77
  • 3,361 POSTS
also drain the fuel tank and put fresh fuel in with some injector cleaner. it will help clean out the system.
Aug 13, 2008 at 8:55 AM
