2005 Chevy Silverado climate control
67,523 MILES • V8 • 2WD • AUTOMATIC
PETE5761
The fan does not increase or decrease when you togle the switch. The fan will continue to run when you turn the climate control system off. The main module, the dash part that you turn on or off and adjust the temperature and fan speed, has been replaced. This did not correct the problem.
Thanks for the help
Pete
Jan 29, 2008 at 2:06 AM
BRIAN 1
  • 1,030 POSTS
this might help.found this bulletin.Some customers may comment that the blower motor is inoperative or continues to run after the vehicle has been shut off.These conditions may be caused by a blower motor control module failure. This failure may occur when the vehicle is operated in ambient temperature conditions of -23°C (-10°F) or below.Important: Replace the blower motor control module if the vehicle experienced a blower motor control module failure in extremely cold ambient temperature conditions.
Technicians are to replace the blower motor control module, also called the Linear Power Module (LPM).After replacement of the blower motor control module, the customer may notice a slightly higher than expected blower motor speed at any of the blower speed settings.
try this it might help.
Jan 29, 2008 at 12:56 PM
