2005 Chevy Silverado chevy A/C problems
60,000 MILES • V8 • 4WD • AUTOMATIC
PACR75SPNL
I have been having a problem with my ac for the past month. The passanger side a/c blows hot air, while the driver side blows only cold air. could you help me with this problem? Thanks!
Jan 7, 2010 at 12:22 PM
  • 110,251 POSTS
Chances are there is a vacuum leak under the dash. The vent doors are run by vacuum. If they are not working properly due to a leak, this problem will happen.
Check for leaks. With the engine running, you may get lucky and hear a hissing sound that could indicate a leak. Also, make sure the linkage on the passanger side is attached to the actuator and the vent door.
Let me know what you find.
Jan 7, 2010 at 12:26 PM
