Caliper piston wont compress?
55,000 MILES • V8 • 2WD • AUTOMATIC
BSCOTT77
I have a 2005 chevy silverado 2wd 2500. front rght caliper broke and was draging on ground , maybe 30 ft. Had it towed and replaced. i have tried bleeding the brakes a few ways. but it seems theres still air. the piston wont squeeze. whats the solution fluid is good and back brakes are fine. hopefully theres another to get air out besides the very known ways. If it happens to be the master cylinder is there a for sure way to see if its bad. I took it to a place also and they bleed it and couldnt get fronts to work, They saqid take it to this place that has a specialty machine that will get air out and make them worl. Is this true. I would like to do myself if possible thanks bp
Nov 9, 2010 at 2:24 PM
  • 110,248 POSTS
Here is a guide to walk you through the steps of the brake job and it shows how to compress the caliper with a video as well.
https://www.2carpros.com/articles/how-to-replace-front-brake-pads-and-rotors-fwd
and
https://youtu.be/9pwFodKAl5A
Nov 9, 2010 at 11:19 PM
ERIN KIMBERLY GILBERT
I have changed the brake hoses and calipers this my third time and it keeps locking up on me. I have bled the line. Can you give me any suggestion on what I need to do next ?
Jan 30, 2019 at 6:36 AM (Merged)
  • 31,937 POSTS
Check master cylinder pedal clearance, you should have about two to three mm free pedal travel, check this next.
GARRITSON
Brakes problem
2004 Chevy Silverado V8 Two Wheel Drive Automatic 120K miles
the bottom bolt on the caliperis frozen
do I put the heat to the D thing
or is the head of the bolt holding it in place
or start drilling?
CRZYDRVR
  • 432 POSTS
If you are referring to the caliper slide pin, then you should be able to put a 15mm wrench on the pin itself and your 12mm on the other bolt that holds it to the pin.
Jan 30, 2019 at 6:37 AM (Merged)
NINETY SILVERADO
  • 8 POSTS
I replaced a caliper on a 1990 Chevy 1500 with the heavy duty chassis, and I need to know how tight to make the caliper bolts. Right now they are pretty snug, but not really tight.
DOCFIXIT
  • 18,828 POSTS
28-35 ft.lbs.
NINETY SILVERADO
  • 8 POSTS
Thanks a lot!
Is there a place online where I can find bolt torque specs for my vehicle?
DOCFIXIT
  • 18,828 POSTS
Mitchel on demand or AllData
NINETY SILVERADO
  • 8 POSTS
Neither of those are free, are they?
JOHN84
My caliper bolts are what I believe are called star bolts. I have not been able to loosen them to remove caliper from the mounting frame. I have purchased the allen wrench type and a socket type star drivers but they do not seem to seat well enough to allow me to put enough force on the bolts to loosen them. The drivers slip out of the bolt, they do not seat as solidly as a allen type bolt I am used to on my other cars. Am I missing something here? Any suggestions?
MERLIN2021
  • 17,250 POSTS
Size is a Torx T-60, should seat OK tap it in or clean out any road grime with brakkleen. If you MUST, heat the mount where it screws in with a torch, they do have locktite on the threads. Be carful not to melt the rubber boots on the ball joints! You mayu need a new hardware kit if the rubbers burn on the slides!
