2005 Chevy Silverado 2005 Chevy Silverado Crew Cab A/C
55,000 MILES • V8 • 2WD • AUTOMATIC
STREETRACER
This weekend I had my car detailed, when I drove it in I had the A/C on but when I drove out the A/C no longer would blow. The lights all work on the instrument panel but when I turn it on nothing happens. The heater has the same issue, I looked at my fuse panel in the engine compartment and none are blown, I also checked my belts and they both are there. So what could it be? Why would it not blow at all? If I change it from cold to hot I can sorta tell the difference in temp but that’s it. Any help would be appreciated.
Oct 12, 2008 at 9:55 PM
RHALL77
  • 3,361 POSTS
check and make sure they didnt disconnect or break a electrical connector off.
Oct 13, 2008 at 5:33 AM
STREETRACER
I have checked the wireing but can not find anything that is not hooked up.
Oct 13, 2008 at 2:02 PM
RHALL77
  • 3,361 POSTS
sounds like a possible motor or resistor. wiggle the wiring first, if that doesnt work, take a hammer and lightly tap the motor and see if it turrns on. a screw driver handle will also work to.
Oct 14, 2008 at 12:13 AM
