2005 Chevy Silverado
VOLTRON
Electrical problem
2005 Chevy Silverado V8 Four Wheel Drive Automatic
I am trying to figure out why I am not reading power from the battery feed wire (red) on my 7 pin connector. My truck is a 2005 Chevy Silverado pickup with the heavy duty towing package/wiring harness. Is there a fuse for this leg? if so where? or is it direct tap from battery somewhere? please help! THANK YOU.
Mar 21, 2009 at 5:26 PM
BMRFIXIT
  • 19,053 POSTS
Can you elaborate a pit more pin # 7 on what connector or what is the problem that you are trying to fix
Mar 21, 2009 at 11:37 PM
VOLTRON
At the connection point on the truck, all other pins test out properly, i.e. when brakes applied test light lights same with blinkers and running lights. However when I clip my tester from ground (-) pin to the positive (+) pin the tester does not light. I have taken a volt meter to confirm. This problem is affecting the interior light of my enclosed box trailer as the switch is not recieving power. I have also checked continuity between the switch and the connector (trailer end) to ground and it is good. Should the battery feed pin have constant power? I tried testing while headlights are on,also while cargo and truck interior lights on and still recieve no power at this (+) pin.
Mar 22, 2009 at 5:06 AM
BMRFIXIT
  • 19,053 POSTS
Still have no idea what pin you are looking at this is the wiring diagram for the interior lights and body control module
https://images.2carpros.com/forum/automotive_pictures/99387_Graphic1_269.jpg
https://images.2carpros.com/forum/automotive_pictures/99387_Graphic2_123.jpg
Mar 22, 2009 at 2:15 PM
