2005 Chevy Silverado
20,000 MILES • V8 • 2WD • AUTOMATIC
JIM CRAWFIS
when I first start up my truck and either depress the brake pedal or turn the steering wheel there is a snapping noise from the brake pedal area .This only happens when it is cold out.once I use the brakes or turn the wheel a little it goes away.I noticed when it's hot out it will not make the noise. I happens when the truck is not moving.I think it has something to do the power steering pump or a relief valve or check valve,because it goes away after I turn the wheel a couple times.
Oct 27, 2008 at 11:56 AM
DENNYP
  • 1,824 POSTS
Is this happening when the truck is moving or stationary?
Oct 28, 2008 at 1:27 AM
JIM CRAWFIS
the noise is only when I first start up the truck,before I move the truck
Oct 28, 2008 at 2:27 AM
DENNYP
  • 1,824 POSTS
xTooltipElement
Service Information
2005 Chevrolet Chevy C Silverado - 2WD | Sierra, Silverado (VIN C/K) Service Manual | Preliminary Information | Document ID: 2153762
#PIT3779J: Squeak Noise On Brake Apply - keywords booster cylinder disc drum fluid front master rub - (Jun 16, 2008)
Subject: Squeak Noise On Brake Apply
Models: 2004-2007 Buick Rainier
2007-2008 Cadillac Escalade, Escalade ESV, Escalade EXT
2007-2008 Chevrolet Avalanche, Silverado, Suburban, Tahoe
2008 Chevrolet Malibu
2004-2006 Chevrolet SSR
2004-2008 Chevrolet Trailblazer, Trailblazer EXT and Trailblazer SS
2005-2007 Chevrolet Silverado Classic with RPO JF3 or JF7
2004-2008 GMC Envoy, Envoy XL and Envoy XUV
2007-2008 GMC Sierra, Yukon, Yukon Denali, Yukon XL, Yukon Denali XL
2005-2007 GMC Sierra Classic with RPO JF3 or JF7
2008 Pontiac G6
2008 Saturn Aura
EXCEPT HYBRID YUKON AND TAHOE MODELS RPO HP2
This PI was superseded to update models. Please discard PIT3779H.
The following diagnosis might be helpful if the vehicle exhibits the symptom(s) described in this PI.
Condition/Concern:
Important: DO NOT USE THIS PI FOR THE HYBRID YUKON AND TAHOE MODELS.
Some customers may comment on a squeak noise when the brake pedal is applied or when released. This noise is normally heard when the brake pedal is slowly applied with the engine on or off, but can occur when the brake pedal is released. The noise may be isolated to the master cylinder area.
Recommendation/Instructions:
To correct this concern, remove as much of the old brake fluid from the master cylinder as possible and refill with a modified DOT 3 brake fluid, P/N·88862806 (in Canada, use P/N·88862807). Depress and release the brake pedal five times to allow the new fluid to enter the system.
Note: It is not necessary to flush the complete brake system with the modified dot 3 fluid to correct this noise.
Part Information
Part Number
Description
Qty
88862806
Brake Fluid, DOT 3
1
(In Canada 88862807)
Please follow this diagnostic or repair process thoroughly and complete each step. If the condition exhibited is resolved without completing every step, the remaining steps do not need to be performed.
GM bulletins are intended for use by professional technicians, NOT a "do-it-yourselfer". They are written to inform these technicians of conditions that may occur on some vehicles, or to provide information that could assist in the proper service of a vehicle. Properly trained technicians have the equipment, tools, safety instructions, and know-how to do a job properly and safely. If a condition is described, DO NOT assume that the bulletin applies to your vehicle, or that your vehicle will have that condition. See your GM dealer for information on whether your vehicle may benefit from the information.
WE SUPPORT VOLUNTARY TECHNICIAN CERTIFICATION
© 2008 General Motors Corporation. All rights reserved.
It could also be a worn brake pedal assembly or a sticky brake switch.
Oct 28, 2008 at 2:57 AM
