Login
Join
Ask a Question
Questions by Vehicle
Repair Topics
Testing / Diagnostics
Repair & Service Guides
Symptoms
Warning Lights
Trouble Codes
How It Works
Videos
Login
Become a Member
Home
Chevrolet
Silverado
2005 Chevy Silverado
2005 CHEVROLET SILVERADO
27,500 MILES • 6 CYL • 2WD • AUTOMATIC
JWGREER
MEMBER
1 POST
HOW DO YOU REPLACE A ENGINE COOLANT TEMP SENSOR, ALSO WHERE IS THE THERMOSTAT LOCATED ON THE COOLING SYSTEM.
Sep 27, 2008 at 9:50 AM
BLACKOP555
Experienced Mechanic
drain fluid level bellow sensor so it dont leak out. next step disconnect the electircal connector then unbolt the sensor.
to put on new one teflon the threads and screw it in, hook it back up your good to go.
thermostat is at the thermostat housing, end of upper radiator hose.
Sep 27, 2008 at 12:49 PM
Add image or video
Ask a new question
Engine won't start
Engine stalls while driving
