2004 Chevy Silverado Wiper motor speed problems
99,786 MILES • V8 • 2WD • AUTOMATIC
ALAN89
so it turns out my wipers just stopped working the other day. Today i got around to replacing the motor assembly on the wipers and only the high speed works. the variable speeds do not work, also the washer fluid doesnt shoot out when i need it to. what can i do to fix the problem?
Dec 3, 2009 at 12:59 PM
  • 110,248 POSTS
I need you to check to see if you are getting power to the both the wiper motor and the W/S washer motor. If you are not, chances are the switch has gone bad.
Let me know what you find.
Dec 7, 2009 at 2:53 AM
