2004 Chevy Silverado Truck vibrates
90,000 MILES • V8 • 2WD • AUTOMATIC
DAVIDDEAL
My truck seems to vibrate when it is going anything but slow (maybe over 35 MPH?). I can't tell if it's coming from the front or back and it isn't extreme, just enough for me to notice it on an otherwise-smooth road. I just checked my tire pressure and one was fairly low, but I filled it up and drove it right after. That didn't solve the problem. My tread is fairly low (probably only a couple mm's from needing replacing).
Any suggestions on what is causing this? Or, even better, an economical/efficient "process of elimination" I can follow to try to locate the problem?
Thanks.
Oct 29, 2009 at 3:56 AM
MERLIN2021
  • 17,250 POSTS
Try looking at the tranny tailshaft mount, and the U-Joints. Though the U-joints should make a squeaking noise.
Oct 29, 2009 at 6:57 AM
