2004 Chevy Silverado squeaks
60,000 MILES • V8 • 4WD • AUTOMATIC
MTI215
when traveling under 10mph i hear loud squeaking coming from the middle of my truck as i speed up the squeaking gets faster and faster until it is no longer heard until i slow back down. it does not matter if i am on the brake or not or traveling forward or reverse. i think it is the driveshaft but not sure. any help would be appreciated. thanks
Jan 24, 2008 at 5:43 AM
BRIAN 1
  • 1,030 POSTS
sounds like a bad u-joint.you can check it by unbolting the driveshaft at the rear diff and move the u-joint back/fourth and check for binding or if its frozen.hope this helps.
Jan 24, 2008 at 10:02 AM
