2004 Chevy Silverado speedometer problem
76,000 MILES • V8 • 4WD • AUTOMATIC
LANCERSTUNNING
I noticed the other day my speedometer needle does not return to 0. It starts a 35 and as i speed up it will go to 120 while i am only going about 65 or so. There are no fault codes in the computer nor is there a check engine light on. No matter how long the truck is off it acts this way
Jul 9, 2008 at 4:08 PM
AIRSOFTSOLDRECN9
  • 348 POSTS
Disconnect the electrical connector speedometer sensor at the output shaft on the transmission. Check to see if the speedometer guage drops to zero. If not then you need to check the slosh panel circuit board for proper voltage (on the back of the instrument panel). (should be 12 V)
Jul 9, 2008 at 4:31 PM
