Around a week ago the speedometer just went out. Before it went out the needle would would get stuck in a position and I would have to restart the vehicle a few times before the needle would end up in the right position, at 0 MPH. it would make a gch gch gch noise when it would be reseting itself. Do you think this is the head unit or the cable? Now the needle does not move at all. Other than this the truck is fine I would just like to know what my speed is and how to fix this problem. The speedo cable is on the top of my trans, runs over the frame under the driver side, up through the floor board then to what seems a box under the dash( is this the head?), but does not seem right behind the gauge, alittle to the right and back around 10 inches. It has a splice in it under the cab right before it goes through the floor board. what should I do first and what should I look for?
Thank you
Paul Haley USMC
Thank you
Paul Haley USMC
Feb 21, 2008 at 1:53 AM
