2004 Chevy Silverado spark plugs
200,000 MILES • V8 • 4WD • AUTOMATIC
BRANDINO WOSER
I was wondering how to remove the plug wires in my truck. I am not familiar with the metal casing around the plugs. Any help would be greatly appreciated.
Thanks
Jun 29, 2009 at 7:02 PM
SERVICE WRITER
  • 9,123 POSTS
Thses can be a hassle to get out. I use a spark plug wire removal tool to try to work them off in one piece with out mangleing them. If you are doing the wires, try to get them out first. Using a twisting pulling motion the heat sheilds can be removed...sometimes. What I might try next time is to place a deep socket into the sheild that is as close as possible to the diameter of the sheild so I can get a better grip and not crush it. I have seen techs pull these and toss them. I try to salvage and re-use them or replace the ones I can't. They are there for a reason as I see it.
Jun 29, 2009 at 10:05 PM
