2004 Chevy Silverado Slight noise simular to wheel bearing?
65,000 MILES • V8 • 4WD • AUTOMATIC
STEVE931
  • 12 POSTS
When do the front hubs need to be serviced.When you disenguage the front drive it seem,s to still have the hubs locked in and the cv joints are turning all the time. How do you disenguage front hubs.
Apr 4, 2008 at 1:50 PM
DENNYP
  • 1,824 POSTS
If the front wheels spin, the cv axles will spin also. They are splined to the hubs.
Apr 4, 2008 at 4:31 PM
STEVE931
  • 12 POSTS
[quote:0cfa4de704="dennyp"]If the front wheels spin, the cv axles will spin also. They are splined to the hubs.[/quote:0cfa4de704] Thank you for your time. Are there any routine service needs for front hubs or bearings. Again I appreciate your time in this matter. steve931
Apr 5, 2008 at 10:34 PM
DENNYP
  • 1,824 POSTS
The front hubs can't be serviced. The front diff fluid should be changed every 50k. The transfer case fluid should be changed every 50k.
Apr 7, 2008 at 1:59 PM
