2004 Chevy Silverado Running Hot???
2004 CHEVROLET SILVERADO
68,750 MILES • V8 • 4WD • AUTOMATIC
SLIDOGNITE
Temp. went up. Coolant level was low, added coolant. Temp level was fine but had to add more coolant. No leakes anywhere. Top hose not hard . Heater is blowing heat. Help!!!!!
Oct 1, 2010 at 10:22 AM
Might want to replace the thermostat could be sticking if there's no leak, radiator not clogged and water pump doing its job
Oct 1, 2010 at 10:58 AM
YOUKNOWMYNAME67
  • 25 POSTS
[quote:00a8bd2d82="slidognite"]Engine Cooling problem
2004 Chevy Silverado V8 Four Wheel Drive Automatic 68750 miles
Temp. went up. Coolant level was low, added coolant. Temp level was fine but had to add more coolant. No leakes anywhere. Top hose not hard . Heater is blowing heat. Help!!!!![/quote:00a8bd2d82]
depending how hot it was and how far it ran i would check around the intake to see if you have a small leak from the gasket and also check the heater hose assembly as they tend to have some problems leaking. make sure to check while the vehicle is running so there is some pressure and use a flashlight to see the whole area.
Oct 4, 2010 at 11:22 AM
