2004 Chevy Silverado roof marker lights
BOUTS
  • 2004 CHEVROLET SILVERADO
  • V8
  • 4WD
  • 130,000 MILES
My roof marker lights will not work. The lamps are fine I looked in the owners manual and it does not show which fuse is for the lights.
Monday, December 7th, 2009 AT 12:10 PM
  • 109,885 POSTS
Actually, the same fuse that runs the parking lights runs them too. So, if you have parking lights, they should be on. What you will need to do is remove each light, one at a time to see where the power loss is located. The power runs in a series, so the first bulb is most likely the problem.
Monday, December 7th, 2009 AT 1:24 PM
