where is the oil pressure sending unit located and do i need special tools to change?
2004 CHEVROLET SILVERADO
31,000 MILES • V8 • 2WD • AUTOMATIC
BIGRIGDUCE
Mar 3, 2009 at 5:28 PM
BLUELIGHTNIN6
  • 16,542 POSTS
Engine oil pressure sensor is pictured below..top rear of engine. No special tools needed for replacement.
https://images.2carpros.com/forum/automotive_pictures/261618_Noname_280.jpg
Thanks for using 2CarPros.com!
May 1, 2021 at 6:53 AM
SQM
  • 6,383 POSTS
The engine oil pressure sensor is located on the rear center of the engine block, near the top (see diagram below).
It can be replaced easily with simple hand tools.
First remove the wiring connector then unscrew the thread from the engine.
https://www.2carpros.com/articles/high-oil-pressure
https://www.2carpros.com/articles/high-or-low-engine-oil-pressure
Oct 22, 2021 at 2:02 PM
