2004 Chevy Silverado Oil Consumption
44,000 MILES • V8 • 4WD • AUTOMATIC
GREG JOHNSON
My truck runs great but runs through a quart of oil between changes. It doesn't leak anywhere but why does it eat the oil?
Jan 17, 2008 at 12:58 AM
THE FACTORY MAN
  • 50 POSTS
How much oil does it use in how many miles? Do you expect it not to use any oil? Many manufactures will not consider that an engine is a problem unless it uses more than 1 qt in 2000 miles.
Feb 29, 2008 at 2:37 AM
JACKSKI
  • 11 POSTS
My 2002 Silverado 2wd, 5.3 does the same, 1/2 quart after 1000 to 1500 miles, then the other half close to 3000, i thought it might be just durning break in, but its been that way up till now at 65000, and thats being easy on it most of the time, i also have a 1999 Chevy Venture van, piece of junk by the way, but its 3.4 v6 may use just 1/2 quart closer to 4000 miles and thats at 70 o 80 mph, plus alot of starting and stopping, I may try some synthetic oil to see if any different. jackski
Feb 29, 2008 at 10:45 AM
MASTERTECHTIM
  • 4,750 POSTS
did it just start using oil? these lower intake gaskets go bad all the time and one symptom is a internal engine vacuum leak which will cause you to burn oil.
Feb 29, 2008 at 10:50 AM
