2004 Chevy Silverado need help
65,000 MILES • V8 • 2WD • AUTOMATIC
ALISONORENDER
I recently went camping at a lake and brought my jet ski. I had it in the bed of my truck so i had to back it up into the water, to drop it down in the water. Now, i never turned off the engine but shortly after dropping it in the water my truck started sputtering and shaking and then just stalled out and wouldnt start again. Also the check engine light went on. I had to get it towed home but i had a friend with a diagnostic machine so he came to check it and im pretty sure it read P 300 and in my manual it said it was a "cylinder misfire". Would this be an easy fix? And what do u think the price range would be around?
Jun 1, 2010 at 5:49 PM
MHIMMEL
  • 30 POSTS
How far did you drive it into the water? if you went too deep you may have sucked water in through the air intake and right into your engine. If you think this happened, go ahead and change your oil a couple of times and see if that works. I had a jeep and went into some deep water and ended up sucking water into my engine through the intake. It wouldnt start so i towed it home, changed the oil, and it started right up. Let me know what you think.
Jun 23, 2010 at 7:03 AM
