2004 Chevy Silverado Key Won't Turn
48,000 MILES • V8 • 2WD • AUTOMATIC
SHAYKANA
My key won't turn in the ignition it will beep when in if the door is open but it won't turn. How do I fix this?
Feb 25, 2009 at 4:41 PM
BLUELIGHTNIN6
  • 16,542 POSTS
Try using WD40 to lubricate the tumblers. Other great information about this common problem can be found at the following link.
http://www.2carpros.com/first_things/why_wont_my_ignition_switch_turn.htm
Thanks for using 2CarPros.com!
Feb 25, 2009 at 4:59 PM
