What you may have done was shorted out a really, if your brights come on and off is the same really, change of those relays around and see if your lights shut off, there are also four fuses to the brights and two for the dims, the BCM runs a lot of other options if they are still working I do not think you damaged it 1. Fog lamps, 2. Interior lights, 3. Brake light warning indicator, 4. Turn signals switch, if those accessories are still operating I do not think there is any damage, the headlight relays are located underhood fuse block left side of engine compartment.
SPONSORED LINKS
Wednesday, August 26th, 2009 AT 6:41 PM
