2004 Chevy Silverado grinding noise
118,000 MILES • V8 • 4WD • AUTOMATIC
BLAK6766
For some reason I get a grinding noise fron the front end only when im turning, I suspect it the be the hub assembly but would that be the symtoms of a bad hub assembly?
Aug 2, 2008 at 3:52 AM
BLACKOP555
  • 10,386 POSTS
could either be the bearing assembly or a bad cv joint.
jack up vehicle and feel for looseness of the wheel, if play is noted bearing shoudl be replaced.
Aug 2, 2008 at 6:07 AM
