2004 Chevy Silverado fan swithc
70,000 MILES • V8 • 4WD • AUTOMATIC
KCRACE
The 0-5 switch that I use to turn the fan up or down only works on 5 now, is it the switch that needs replaced or something else? If its just the swith where can I get one besides the dealer? If it is something else what would it be and where can I find the new part?
Mar 3, 2010 at 11:40 AM
BLUELIGHTNIN6
  • 16,542 POSTS
first check for faulty blower motor relay. if the relay is OK then suspect faulty blower motor resistor. a local auto part store should carry or be able to get these parts.
Mar 3, 2010 at 11:48 AM
BLUELIGHTNIN6
  • 16,542 POSTS
actually looking at repair manual it doesn't appear your vehicle uses a blower motor relay. if its working in high setting then the blower motor resistor pack will need replaced.
Mar 4, 2010 at 7:54 AM
