What do you have to do to change the the cooling system fluid
Sep 25, 2010 at 9:39 AM
FACTORYJACK
✓Experienced Mechanic
They don't offer a radiator drain plug, so you need to either disconnect the lower radiator hose at the radiator, or the coolant pump. Disconnecting one of the heater hoses that attach at the pump will also drain some from the block, from behind the thermostat.
