radiator drain plug?
22,000 MILES • V8 • 4WD • AUTOMATIC
DABRAHA
How do you open the radiator drain valve?? I see no handle to open the valve?
May 5, 2009 at 9:29 AM
DANNY L
  • 5,648 POSTS
Hello, I'm Danny.
Here is the information you requested. Here is a tutorial showing how to change the engine coolant if you plan on doing so:
https://www.2carpros.com/articles/coolant-flush-and-refill-all-cars
I've attached a few pictures below showing how to remove and replace the radiator draincock and its location. Hope this helps and thanks for using 2CarPros.
Jun 29, 2021 at 5:01 PM
