2004 Chevy Silverado Brakes apply themselves
54,000 MILES • V8 • 4WD • AUTOMATIC
ROCKSTEW1
What could cause the brakes on my vehicle to become pressurized to the point that the vehicle will stop without applying the brake pedal? I replaced the right front caliper while doing a brake job.and after that the problem began. The brake pedal will become very stiff,and the brakes will lock up.
Jun 7, 2010 at 9:41 AM
DENNYP
  • 1,824 POSTS
Try bleeding the brake system. This is going to require the use of a Tech2 scan tool to perform the automated ABS bleed procedure. All of the air must be removed from the system.
Jun 7, 2010 at 4:15 PM
