2004 Chevy Silverado 2004 Chevy Silverado Squeaks Only When
83,000 MILES • V8 • 4WD • AUTOMATIC
JOHN22USAF
Have had this truck for about a year now, recently started to squeak when accelerateing at low speeds (typically below 35 mph). Have tried changeing the oil, and belts appear fine. Squeak only occurs when in drive and accelerateing, and not in reverse or a neutral/park idle. Brakes have already been ruled out. Any ideas?
Apr 19, 2008 at 2:30 PM
MERLIN2021
  • 17,250 POSTS
Check the tensioner pulley, 83,000 miles means your close to needing a belt and tensioner, when you take the belt off, try spinning the a/c pulley if there is any binding, replace the pulley and bearing, it comes as an assembly...
Apr 19, 2008 at 11:12 PM
