2004 Chevy Silverado
2004 CHEVROLET SILVERADO
CAMARO1988
Engine Mechanical problem
2004 Chevy Silverado V8 Two Wheel Drive Automatic
How do I change a bent fuel line in my silverado?
Aug 8, 2010 at 12:24 AM
MERLIN2021
  • 17,250 POSTS
Depends on where the bend is? If you have a bend along a frame rail with plenty on line on each side of the bend, buy the same size steel line, and two nions for that size line. Use a tubing cotter and cut the bent section out, then splice in the new line. Tighten and inspect for leaks.
Aug 8, 2010 at 12:40 AM
