2004 Chevy Silverado
2004 CHEVROLET SILVERADO
ABCAUTO
  • 11 POSTS
2004 Chevy Silverado V8 Four Wheel Drive Automatic
Working on a 5.3 liter engine. It is running to rich,(it blow black smoke). It had 4 codes
P0134 o2 sensor ckt no activity (bank 1 sensor 1)
P0171 system too lean(bank 1)
P0300 Multi cyl misfire
P1133 enhanced DTC
We replaced the O2 sensor (front drivers side)
The fuel pressure is at a consistent 60 lbs. Could the fuel pressure be too high?
What is our problem?
Mar 19, 2010 at 7:09 AM
Hi abcauto, Welcome to 2carpros and TY for the donation
Fuel Pressure (Key ON Engine OFF) 385-425 kPa (55-62 psi) check the fuel pressure while running with vacuum hose removed from the pressure regulator
P0300 is random misfires normally caused by vacuum leaks and contaminated
Probable causes of an engine running rich are as follows:
1.Fuel pressure not within specs.Can be cause by restricted fuel return line or defective fuel pressure regulator.
2.Defective Oxygen Sensors.
3.Leaking injectors.
4.Coolant temperature sensor out of calibration.
5.Restricted air intake system.
Mar 19, 2010 at 11:49 AM
