2004 Chevy Silverado
104,000 MILES • V8 • 4WD • AUTOMATIC
MJSCAR
changing transmission fluid on a 2004 chevy silverado 4 wheel drive. Is there a filter and easier wasy to add new fluid other than the dip stick area
Sep 25, 2010 at 9:35 AM
  • 110,251 POSTS
You have to remove the transmission pan to see the filter. As far as refilling it, that is the only way to do it.
PS: Make sure to get a composite gasket that it more paper like. The rubber ones and the cork ones are very easy to overtighten and cause a leak.
Sep 25, 2010 at 4:07 PM
