2004 Chevy Silverado
112,000 MILES • V8 • 4WD • AUTOMATIC
KRIEG117
Truck feels like it is missing while idling, when you accelorate hard out on the road the lights will dim and you can see the voltage meter will drop from 14 to about 11. Needed new alternator and battery a while back - dealership installed - had them put on a new belt. I changed the sparkplugs cleaned throttlebody, engine is not throwing any codes.
Feb 27, 2010 at 10:55 AM
  • 110,251 POSTS
It sounds like the alternator is bad. If you loose too much power, it can cause engine problems. Have you had the new alternator load tested?
Feb 27, 2010 at 3:43 PM
KRIEG117
No havent got it tested, had a new one put in at 86000 at the dealership, well what i thought was a new one, it was a reman part but anyway that was my next step to get it checked
Feb 28, 2010 at 8:46 AM
