I have three questions with regards to this vehicle:
1. I have noticed that the steering feels less tight now than when new. Also in slight turns at moderate speed I feel light clunking or chatter in the steering wheel. The dealer said the exhaust was missing some rubber supports but this did not help. I did notice that when the truck got greased when I changed the oil it was better for a short while.
2. I notice especially when putting truck into reverse I hear a clunk and it also feels like it takes a second or two to get into reverse so I don't apply gas immediately after shifting. The 1st to 2nd gear transition is also a little choppy depending upon the traffic conditions. If I accelerate and then lift off the gas in traffic it sometimes shilfts abruptly into 2nd with a jerk.
3. Lastly with a rear tire off (driver) I pulled and pushed on the rotor and noticed slight movement in and out again with a slght clunking noise. This wasn't the rotor moving on the wheel studs it was the whole axle shaft. Is this normal play?
Tks, Bruce
3.
Tks, Bruce
3.
Dec 22, 2006 at 5:49 AM
