2003 Chevy Silverado transmission line quik connects to rad
90,000 MILES • V8 • 2WD • AUTOMATIC
PEANOUNIS
tranning fluid is leaking from quik connect on radiator..has this been a problem for anyone? is there another way 2 fix this leak other then changing out the transmission line hose and or fixtures leading into radiator?
Oct 26, 2008 at 4:48 AM
BLACKOP555
  • 10,386 POSTS
no recalls on it so it isnt a common problem witih the vehicle.
you could use sealant to seal it, but the proper way to do it is to put on a new quick connector or to have a shop put on a threaded line.
Oct 26, 2008 at 6:05 AM
DENNYP
  • 1,824 POSTS
The quick connect fittings are inexpensive and easy to change. You can get them at the dealer.
Oct 27, 2008 at 3:54 AM
BLACKOP555
  • 10,386 POSTS
thank you ^^ :D
Oct 27, 2008 at 1:13 PM
