2003 Chevy Silverado Tailgate
50,000 MILES • 6 CYL • 2WD • AUTOMATIC
GSCORSO
The tailgate latch will not open the tailgate. How difficult is this to repair and can a casual do it yourselfer fix it?
Dec 31, 2007 at 9:47 AM
MIKE H R
  • 3,094 POSTS
When you pull on the latch does the handle feel loose or can you feel some it trying to work? if the handle is loose the connecting rod could be off. if it tries to open then the latches are stuck. You will have to remove the inside tailgate cover to repair the rod. if the latches are stuck try using wd 40 on them to loosen them up to get it open.
Jan 8, 2008 at 2:00 AM
