2003 Chevy Silverado speedometer
80,000 MILES • V8 • 2WD • AUTOMATIC
JFRANKS.65
The speedometer sometimes "jumps" up to a speed , usually 30 or 40 m.p.h. while sitting still.
I can get it back to 0 m.p.h. by jogging the ignition switch to the point of engaging the starter motor several times with the engine off. Any idea of the cause and location of the faulty part? Any help will be greatly appriciated ! Thanks !
Jan 31, 2009 at 2:39 AM
  • 110,251 POSTS
Hi:
It could be the cluster itself or a bad speed sensor on the trans. You need to have the sensor tested.
Feb 2, 2009 at 4:55 AM
