my spare tire will not come down from under truck. There is this "T" lock type thing holding it up when cable is out. How do I get this to release?
Mar 4, 2009 at 6:01 AM
✓Experienced Mechanic
Is the cable going through the T?
Mar 4, 2009 at 7:33 AM
RBLASKA
MEMBER
yes cable extends to the ground. "T" holds the tire
somehow
Mar 4, 2009 at 9:23 AM
Hi:
If the cable goes through the T, then the T must be rusted or corroded in place because the cable is what actually holds the tire in place not the T. The T is used to prevent the cable from comming off the spare tire. Try taking a brass hammer and tapping on the T to see if it will break loose. Be careful that the tire doesn't fall on you.
Let me know if that works.
Mar 4, 2009 at 2:20 PM
RBLASKA
MEMBER
The "T" doesn't seem to be rusted. It holds the tire approx. 2 inches lower than fully tight to truck. Tire and "T" move, rotate & swing slightly. Not rusted. I'm hearing that there are catches on long end of "T"
that goes up into a latch of sorts. How does this release?
Mar 5, 2009 at 12:36 AM
RBLASKA
MEMBER
I discovered that if I put a jack under tire while cable is drawn up tight. Holding the weight of the tire, then the cable and "Tee" comes down easily when cranked out, then let the tire down. "It Worked" but shouldn't be necessary. Thanks for all your help.
Mar 9, 2009 at 1:22 PM
KAT8982
MEMBER
Had the same problem one night coming out of a restrurant and findinding my tire flat..
Keep working it up and down, from none use it does stick . It will loosen then spray cable once you get it all the way down.
Mar 14, 2009 at 1:32 AM
