I have just noticed a very small rear main seal oil leak
160,000 MILES • V8 • 4WD • AUTOMATIC
DAVID WOMMER
I have jsut noticed a very small rear main seal oil leak. If I park the car it may leak a small 1" diameter spot overnight. Is this something I need to have looked at immediately. Can it cause further damage to something else?
Nov 16, 2009 at 1:24 AM
  • 110,246 POSTS
Actually, if you made it to 160K with it just starting, you did really well. As far as concern, if it's that small, you should be fine. Just keep an eye on the oil level. If you keep it full, there shouldn't be a problem.
If you have other qustions, let me know.
Nov 16, 2009 at 2:07 AM
DAVID WOMMER
[quote:cbb089c22d="Jacobandnickolas"]Actually, if you made it to 160K with it just starting, you did really well. As far as concern, if it's that small, you should be fine. Just keep an eye on the oil level. If you keep it full, there shouldn't be a problem.
Joe[/quote:cbb089c22d]
someone had told me that the oil could leake into the transmission and damage the clutch. is that false.
Nov 16, 2009 at 2:41 AM
